[petsc-dev] Install step broken
    Garth N. Wells
    gnw20 at cam.ac.uk
    Mon Feb  1 10:17:50 CST 2016
On 28 January 2016 at 15:40, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Jan 27, 2016 at 9:10 AM, Garth N. Wells <gnw20 at cam.ac.uk> wrote:
>> The 'install' step for master is broken for me since Matt's
>> change ddc4758 (
>> https://bitbucket.org/petsc/petsc/commits/ddc47588dc986180af4263ab160cc4a555099aa9).
>> I can  build and install c502958 fine.
> This change is only in an error branch, and should only be triggered by an
> unsuccessful configure. Can you send configure.log?
I had to unset my PYTHONPATH, which contained mpi4py and petsc4py. Could
something have been imported from petsc4py and messed things up?
I can send configure.log to petsc-maint later, if it would be helpful.
Garth
>   Thanks,
>      Matt
>> Error at 'make install' is:
>> No cached configure in RDict at arch-linux2-c-opt/lib/petsc/conf/RDict.db
>>                                     Traceback (most recent call last):
>>   File "./config/install.py", line 380, in <module>
>>     Installer(sys.argv[1:]).run()
>>   File "./config/install.py", line 373, in run
>>     self.runsetup()
>>   File "./config/install.py", line 334, in runsetup
>>     self.setup()
>>   File "./config/install.py", line 60, in setup
>>     self.setupModules()
>>   File "./config/install.py", line 51, in setupModules
>>     self.setCompilers  = self.framework.require('config.setCompilers',
>>       None)
>> AttributeError: 'NoneType' object has no attribute 'require'
>> makefile:261: recipe for target 'install' failed
>> Garth
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160201/aec7e785/attachment.html>
