[petsc-dev] Install step broken
    Garth N. Wells
    gnw20 at cam.ac.uk
    Thu Feb  4 02:29:47 CST 2016
Just to wrap this thread up, issue was fixed in
https://bitbucket.org/petsc/petsc/commits/5a4feeed41cb1af9234d439bb06ea004d3cfa5c6?at=master
Garth
On 1 February 2016 at 16:17, Garth N. Wells <gnw20 at cam.ac.uk> wrote:
> On 28 January 2016 at 15:40, Matthew Knepley <knepley at gmail.com> wrote:
>> On Wed, Jan 27, 2016 at 9:10 AM, Garth N. Wells <gnw20 at cam.ac.uk> wrote:
>>> The 'install' step for master is broken for me since Matt's
>>> change ddc4758 (
>>> https://bitbucket.org/petsc/petsc/commits/ddc47588dc986180af4263ab160cc4a555099aa9).
>>> I can  build and install c502958 fine.
>> This change is only in an error branch, and should only be triggered by
>> an unsuccessful configure. Can you send configure.log?
> I had to unset my PYTHONPATH, which contained mpi4py and petsc4py. Could
> something have been imported from petsc4py and messed things up?
> I can send configure.log to petsc-maint later, if it would be helpful.
> Garth
>>   Thanks,
>>      Matt
>>> Error at 'make install' is:
>>> No cached configure in RDict at
>>> arch-linux2-c-opt/lib/petsc/conf/RDict.db
>>>   Traceback (most recent call last):
>>>   File "./config/install.py", line 380, in <module>
>>>     Installer(sys.argv[1:]).run()
>>>   File "./config/install.py", line 373, in run
>>>     self.runsetup()
>>>   File "./config/install.py", line 334, in runsetup
>>>     self.setup()
>>>   File "./config/install.py", line 60, in setup
>>>     self.setupModules()
>>>   File "./config/install.py", line 51, in setupModules
>>>     self.setCompilers  = self.framework.require('config.setCompilers',
>>>       None)
>>> AttributeError: 'NoneType' object has no attribute 'require'
>>> makefile:261: recipe for target 'install' failed
>>> Garth
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160204/b0322b4d/attachment.html>
