[petsc-dev] MKL issue
    Stefano Zampini
    stefano.zampini at gmail.com
    Mon Feb  1 08:09:03 CST 2016
2016-01-29 8:54 GMT+03:00 Jeff Hammond <jeff.science at gmail.com>:
> On Thu, Jan 28, 2016 at 9:11 PM, Jed Brown <jed at jedbrown.org> wrote:
>> Stefano Zampini <stefano.zampini at gmail.com> writes:
>> > Just for the records:
>> > I have an installation using the MKL distribution of scalapack but it
>> >  doesn't use IntelMPI
> I don't understand your comment.  MKL ScaLAPACK is build against Intel
> MPI, Open-MPI and (maybe) SGI MPT.
> Because of MPICH ABI compatibility (https://www.mpich.org/abi/), you
> should be able to use the MKL ScaLAPACK libraries compiled against Intel
> MPI with MPICH, MVAPICH2, Cray MPI and any other late-model MPICH
> derivative, so long as the binary representation of MPICH objects does not
> change (e.g. MPI_Status object).
What I meant is that if one doesn't know this and resolves the blacs names
needed by scalapack by just linking against libmkl_blacs_lp64.a (which is
legitimate), then he or she could have such problem, because the
MKLMPI_Get_wrappers symbol is apparently not needed (just searched for by
using libdl calls).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160201/6672e59a/attachment.html>
