[petsc-dev] configure error
Mark Adams mfadams at lbl.gov
Thu Dec 29 04:09:17 CST 2016
--with-batch=0 seems to fix the problem.
On Thu, Dec 29, 2016 at 4:40 AM, Mark Adams <mfadams at lbl.gov> wrote:
> BTW, I cloned this (working) config file and changed to single precision
> and 32 bit ints, and added with-batch=1.
> On Wed, Dec 28, 2016 at 11:20 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> I can reproduce this issue. [we don't notice it normally because
>> default system blas is usually found - so there is no error..]
>> Satish
>> On Wed, 28 Dec 2016, Barry Smith wrote:
>> >   Mark,
>> >    Yes this is odd. You clearly have --download-fblaslapack=1  but then
>> in the file it has
>> > TEST alternateConfigureLibrary from config.packages.fblaslapack(/g
>> lobal/u2/m/madams/petsc/config/BuildSystem/config/package.py:761)
>> > TESTING: alternateConfigureLibrary from config.packages.fblaslapack(co
>> >   Called if --with-packagename=0; does nothing by default
>> >    I suggest try removing all options except the
>> --download-fblaslapack=1 and the compiler names and the --with-batch and
>> see if it goes through. Do not cut and past but type each argument; it
>> could be some strange character being pass in you cannot see.
>> >    Barry
>> > > On Dec 28, 2016, at 9:52 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> > > I am getting an error about blas-lapack, suggesting that I download
>> it, but I seem to be asking to download it. Not sure what the problem is ...
>> > > <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20161229/645bab15/attachment.html>
