[petsc-dev] configure error
    Satish Balay
    balay at mcs.anl.gov
    Thu Dec 29 10:03:48 CST 2016
I suspect blaslpack along with mpi cannot be installed in batch mode anymore.
[at some point all pacakges were installed before reconfigure. And I think this was
switched to - install packages during reconfigure. Ideally there should be proper
dependencies on the 'batch' part - so that only packages that require info from the
batch run should get installed during reconfigure stage..]
BTW: Why use --download-fblaslapack on cray? [and not system blas - like cray-libsci]
Satish
On Thu, 29 Dec 2016, Mark Adams wrote:
> --with-batch=0 seems to fix the problem.
> On Thu, Dec 29, 2016 at 4:40 AM, Mark Adams <mfadams at lbl.gov> wrote:
> > BTW, I cloned this (working) config file and changed to single precision
> > and 32 bit ints, and added with-batch=1.
> > On Wed, Dec 28, 2016 at 11:20 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> >> I can reproduce this issue. [we don't notice it normally because
> >> default system blas is usually found - so there is no error..]
> >> Satish
> >> On Wed, 28 Dec 2016, Barry Smith wrote:
> >> >   Mark,
> >> >    Yes this is odd. You clearly have --download-fblaslapack=1  but then
> >> in the file it has
> >> > TEST alternateConfigureLibrary from config.packages.fblaslapack(/g
> >> lobal/u2/m/madams/petsc/config/BuildSystem/config/package.py:761)
> >> > TESTING: alternateConfigureLibrary from config.packages.fblaslapack(co
> >> >   Called if --with-packagename=0; does nothing by default
> >> >    I suggest try removing all options except the
> >> --download-fblaslapack=1 and the compiler names and the --with-batch and
> >> see if it goes through. Do not cut and past but type each argument; it
> >> could be some strange character being pass in you cannot see.
> >> >    Barry
> >> > > On Dec 28, 2016, at 9:52 PM, Mark Adams <mfadams at lbl.gov> wrote:
> >> > > I am getting an error about blas-lapack, suggesting that I download
> >> it, but I seem to be asking to download it. Not sure what the problem is ...
> >> > > <configure.log>
