[petsc-dev] configure error
Mark Adams
mfadams at lbl.gov
Thu Dec 29 03:40:35 CST 2016
BTW, I cloned this (working) config file and changed to single precision
and 32 bit ints, and added with-batch=1.
On Wed, Dec 28, 2016 at 11:20 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> I can reproduce this issue. [we don't notice it normally because
> default system blas is usually found - so there is no error..]
> Satish
> On Wed, 28 Dec 2016, Barry Smith wrote:
> > Mark,
> > Yes this is odd. You clearly have --download-fblaslapack=1 but then
> in the file it has
> > TEST alternateConfigureLibrary from config.packages.fblaslapack(/
> global/u2/m/madams/petsc/config/BuildSystem/config/package.py:761)
> > TESTING: alternateConfigureLibrary from config.packages.fblaslapack(
> > Called if --with-packagename=0; does nothing by default
> > I suggest try removing all options except the
> --download-fblaslapack=1 and the compiler names and the --with-batch and
> see if it goes through. Do not cut and past but type each argument; it
> could be some strange character being pass in you cannot see.
> > Barry
> > > On Dec 28, 2016, at 9:52 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > > I am getting an error about blas-lapack, suggesting that I download
> it, but I seem to be asking to download it. Not sure what the problem is ...
> > > <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20161229/8ca9912b/attachment.html>
