[petsc-dev] configure error
Satish Balay
balay at mcs.anl.gov
Wed Dec 28 22:20:09 CST 2016
I can reproduce this issue. [we don't notice it normally because
default system blas is usually found - so there is no error..]
Satish
On Wed, 28 Dec 2016, Barry Smith wrote:
> Mark,
> Yes this is odd. You clearly have --download-fblaslapack=1 but then in the file it has
> TEST alternateConfigureLibrary from config.packages.fblaslapack(/global/u2/m/madams/petsc/config/BuildSystem/config/package.py:761)
> TESTING: alternateConfigureLibrary from config.packages.fblaslapack(config/BuildSystem/config/package.py:761)
> Called if --with-packagename=0; does nothing by default
> I suggest try removing all options except the --download-fblaslapack=1 and the compiler names and the --with-batch and see if it goes through. Do not cut and past but type each argument; it could be some strange character being pass in you cannot see.
> Barry
> > On Dec 28, 2016, at 9:52 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > I am getting an error about blas-lapack, suggesting that I download it, but I seem to be asking to download it. Not sure what the problem is ...
> > <configure.log>
