[petsc-dev] Make PetscHash publicly accessible
Jed Brown
jed at jedbrown.org
Fri Apr 22 09:52:38 CDT 2016
Matthew Knepley <knepley at gmail.com> writes:
> You are wrong in this case. The HashIJ is not trivial, and cannot be done
> easily inline. What is the problem here?
$ git grep -l 'PetscHashIJ[^K]'
src/sys/examples/tests/ex26.c
src/sys/utils/hash.h
$ git grep -l 'PetscHashJK'
src/dm/impls/plex/plexfem.c
src/mat/impls/preallocator/matpreallocator.c
But matpreallocator.c doesn't actually use the linked list aspects of
PetscHashJK, so it's memory overhead (two unused pointers plus padding
per entry) for nothing.
$ git grep -l 'PetscHashIJKL'
src/dm/impls/plex/plexinterpolate.c
This is actually used, but I think the implementation (below) accurately
fits my description of wrapping khash primitives with imaginary error
checking. Lawrence, do you just want a general-purpose hash table or do
you specifically want Matt's hash/linked-list structure?
#undef __FUNCT__
#define __FUNCT__ "PetscHashIJKLCreate"
PETSC_STATIC_INLINE PetscErrorCode PetscHashIJKLCreate(PetscHashIJKL *h)
PetscErrorCode ierr;
PetscFunctionBegin;
PetscValidPointer(h, 1);
ierr = PetscNew((h));CHKERRQ(ierr);
(*h)->ht = kh_init(HASHIJKL);
PetscFunctionReturn(0);
#undef __FUNCT__
#define __FUNCT__ "PetscHashIJKLResize"
PETSC_STATIC_INLINE PetscErrorCode PetscHashIJKLResize(PetscHashIJKL h, PetscInt n)
PetscFunctionBegin;
(kh_resize(HASHIJKL, (h)->ht, (n)));
#undef __FUNCT__
#define __FUNCT__ "PetscHashIJKLKeySize"
PETSC_STATIC_INLINE PetscErrorCode PetscHashIJKLKeySize(PetscHashIJKL h, PetscInt *n)
PetscFunctionBegin;
((*n) = kh_size((h)->ht));
#undef __FUNCT__
#define __FUNCT__ "PetscHashIJKLPut"
PetscHashIJKLPut - Insert key in the hash table
Input Parameters:
+ h - The hash table
- key - The key to insert
Output Parameter:
+ missing - 0 if the key is present in the hash table, 1 if the bucket is empty (never used), 2 if the element in the bucket has been deleted
- iter - Iterator into table
Level: developer
.seealso: PetscHashIJKLCreate(), PetscHashIJKLSet()
PETSC_STATIC_INLINE PetscErrorCode PetscHashIJKLPut(PetscHashIJKL h, PetscHashIJKLKey key, PetscHashIJKLIter *missing, PetscHashIJKLIter *iter)
PetscFunctionBeginHot;
*iter = kh_put(HASHIJKL, (h)->ht, (key), missing);
#undef __FUNCT__
#define __FUNCT__ "PetscHashIJKLSet"
PetscHashIJKLSet - Set the value for an iterator in the hash table
Input Parameters:
. iter - An iterator into the table
- value - The value to set
Level: developer
.seealso: PetscHashIJKLCreate(), PetscHashIJKLPut(), PetscHashIJKLGet()
PETSC_STATIC_INLINE PetscErrorCode PetscHashIJKLSet(PetscHashIJKL h, PetscHashIJKLIter iter, PetscInt value)
kh_val((h)->ht, iter).n = value;
#undef __FUNCT__
#define __FUNCT__ "PetscHashIJKLGet"
PetscHashIJKLGet - Get the value for an iterator in the hash table
Input Parameters:
Output Parameters:
. value - The value to get
Level: developer
.seealso: PetscHashIJKLCreate(), PetscHashIJKLPut(), PetscHashIJKLSet()
PETSC_STATIC_INLINE PetscErrorCode PetscHashIJKLGet(PetscHashIJKL h, PetscHashIJKLIter iter, PetscInt *value)
*value = kh_val((h)->ht, iter).n;
#undef __FUNCT__
#define __FUNCT__ "PetscHashIJKLClear"
PETSC_STATIC_INLINE PetscErrorCode PetscHashIJKLClear(PetscHashIJKL h)
PetscFunctionBegin;
kh_clear(HASHIJKL, (h)->ht);
#undef __FUNCT__
#define __FUNCT__ "PetscHashIJKLDestroy"
PETSC_STATIC_INLINE PetscErrorCode PetscHashIJKLDestroy(PetscHashIJKL *h)
PetscFunctionBegin;
if ((*h)) {
if ((*h)->ht) {
kh_destroy(HASHIJKL, (*h)->ht);
(*h)->ht = NULL;
ierr = PetscFree((*h));CHKERRQ(ierr);
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160422/7a82a1db/attachment.sig>
