[petsc-dev] Make PetscHash publicly accessible
Matthew Knepley
knepley at gmail.com
Fri Apr 22 09:31:31 CDT 2016
On Fri, Apr 22, 2016 at 9:25 AM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > Sweeping generalization not actually true. The wrappers do setup the
> > particular
> > keys we want inside PETSc,
> All 3 invocations of KHASH_INIT amid 500 lines.
You are wrong in this case. The HashIJ is not trivial, and cannot be done
easily inline. What is the problem here?
Matt
> > and do bundle some multiple operation calls.
> Some, yes, though some of that bundling produces demonstrably less
> efficient interfaces.
> commit da33aca0a8f0fe1631697dcf59d191f75b34b5c6
> Author: Matthew G. Knepley <knepley at gmail.com>
> Date: Fri Nov 8 15:40:59 2013 -0600
> Sys ex26: Jed is right that this is much faster
> Modified src/sys/examples/tests/ex26.c
> diff --git a/src/sys/examples/tests/ex26.c b/src/sys/examples/tests/ex26.c
> index e8cc50a..30ed523 100644
> --- a/src/sys/examples/tests/ex26.c
> +++ b/src/sys/examples/tests/ex26.c
> @@ -22,8 +22,13 @@ int main(int argc, char **argv)
> key.i = PetscMin(i, j);
> key.j = PetscMax(i, j);
> +#if 1
> + khint_t ret, idx = kh_put(HASHIJ, table->ht, key, &ret);
> + if (ret == 1) kh_val(table->ht, idx).n = newp++;
> +#else
> ierr = PetscHashIJGet(table, key, &p);CHKERRQ(ierr);
> if (p < 0) {ierr = PetscHashIJAdd(table, key,
> newp++);CHKERRQ(ierr);}
> +#endif
> ierr = PetscHashIJDestroy(&table);CHKERRQ(ierr);
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160422/a8b5476f/attachment.html>
