[petsc-dev] broken options handling with intel 16.0 compilers on mac OS
    Satish Balay
    balay at mcs.anl.gov
    Sun Sep 20 09:04:22 CDT 2015
Hm - I would suggest doing a minimal build build with:
--with-cxx=0
--with-clib-autodetect=0 --with-fortranlib-autodetect=0 LIBS="/opt/intel-16.0/compilers_and_libraries_2016.0.083/mac/compiler/lib/libifcore.a"
And see if that makes a difference.
Satish
On Sat, 19 Sep 2015, Blaise A Bourdin wrote:
> Hi,
> I was traveling and did not have time to finish investigating, but there seems to be an issue with fortran get_command_argument and friends in mixed language mode. I will continue to investigate and will report back.
> Blaise
> > On Sep 19, 2015, at 10:18 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > [from the available logs] its not clear what the issue is.
> > PETSc fortran interface attempts to use getarg_() and iargc_() [fortran
> > library functions] - or its variants - directly from C.
> > This usage is non-standard and messy [and some compiler folks - said -
> > its unsupported usage].
> > Also - configure attempts to guess the fortran link libraries - and
> > constructs a link command cCompilerLibs + cxxCompilerLibs +
> > fortranCompilerLibs.
> > Perhaps there is a bug in this detection code - thats triggering this
> > error. Its verifyable by attempting to use:
> > --with-clib-autodetect=0 --with-clib-autodetect=0 --with-cxxlib-autodetect=0 LIBS='liblist'
> > where 'liblist' should be determined manually - for the linking of
> > C/fortran/CXX to work correctly.
> > My fix attempts to call command_argument_count(),
> > get_command_argument() directly from fortran - and if that doesn't
> > work - then its likely a compiler bug..
> > [which one can try to replicate with a simple test code]
> > Satish
> > On Thu, 17 Sep 2015, Jeff Hammond wrote:
> >> Please report this via premier.intel.com.
> >> Jeff
> >> On Wed, Sep 16, 2015 at 11:13 AM, Blaise A Bourdin <bourdin at lsu.edu> wrote:
> >>> Hi,
> >>> I am testing intel 16 compilers under mac OS, and notice that options
> >>> handling for all past and current versions of petsc is broken in fortran
> >>> (options are not parsed).
> >>> I narrowed it down to *argc at start.c:168 always being 0 when intel 16 is
> >>> used (but taking the right value using intel 15 or gcc 5), but I can’t find
> >>> my way through the multiple macros to figure out what is really the matter…
> >>> The problem does not seem to arise under linux with the same compilers.
> >>> Any idea of what is going on? Any test I can run to help (I assume that
> >>> you don’t have a test box with the latest intel compilers)? Is it a petsc
> >>> bug or an intel bug?
> >>> I use an up to date pets-dev master, and the configure.log file is
> >>> available at
> >>> https://filestogeaux.lsu.edu/public/download.php?FILE=bourdin/89329uFByT9
> >>> Thanks,
> >>> Blaise
> >>> Department of Mathematics and Center for Computation & Technology
> >>> Louisiana State University, Baton Rouge, LA 70803, USA
> >>> Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276
> >>> http://www.math.lsu.edu/~bourdin
