[petsc-dev] broken options handling with intel 16.0 compilers on mac OS
    Blaise A Bourdin
    bourdin at lsu.edu
    Mon Sep 21 12:21:17 CDT 2015
> On Sep 20, 2015, at 9:04 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> Hm - I would suggest doing a minimal build build with:
> --with-cxx=0
> --with-clib-autodetect=0 --with-fortranlib-autodetect=0 LIBS="/opt/intel-16.0/compilers_and_libraries_2016.0.083/mac/compiler/lib/libifcore.a"
> And see if that makes a difference.
Satish,
It does help.
Turning off auto detect leads to a functional build, turning it back on leads to a non-functioning one.
The configure.log without auto detect is here:
   https://filestogeaux.lsu.edu/public/download.php?FILE=bourdin/61967j4XaVp
The one with auto detect there:
   https://filestogeaux.lsu.edu/public/download.php?FILE=bourdin/691pPOSRU
The petscconf.h are attached
Desc: petscconf-autodetect.h
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150921/a86a5303/attachment.obj>
Desc: petscconf-noautodetect.h
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150921/a86a5303/attachment-0001.obj>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150921/a86a5303/attachment.txt>
