[petsc-dev] broken options handling with intel 16.0 compilers on mac OS
    Blaise A Bourdin
    bourdin at lsu.edu
    Sat Sep 19 22:22:28 CDT 2015
I was traveling and did not have time to finish investigating, but there seems to be an issue with fortran get_command_argument and friends in mixed language mode. I will continue to investigate and will report back.
Blaise
> On Sep 19, 2015, at 10:18 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> [from the available logs] its not clear what the issue is.
> PETSc fortran interface attempts to use getarg_() and iargc_() [fortran
> library functions] - or its variants - directly from C.
> This usage is non-standard and messy [and some compiler folks - said -
> its unsupported usage].
> Also - configure attempts to guess the fortran link libraries - and
> constructs a link command cCompilerLibs + cxxCompilerLibs +
> fortranCompilerLibs.
> Perhaps there is a bug in this detection code - thats triggering this
> error. Its verifyable by attempting to use:
> --with-clib-autodetect=0 --with-clib-autodetect=0 --with-cxxlib-autodetect=0 LIBS='liblist'
> where 'liblist' should be determined manually - for the linking of
> C/fortran/CXX to work correctly.
> My fix attempts to call command_argument_count(),
> get_command_argument() directly from fortran - and if that doesn't
> work - then its likely a compiler bug..
> [which one can try to replicate with a simple test code]
> Satish
> On Thu, 17 Sep 2015, Jeff Hammond wrote:
>> Please report this via premier.intel.com.
>> Jeff
>> On Wed, Sep 16, 2015 at 11:13 AM, Blaise A Bourdin <bourdin at lsu.edu> wrote:
>>> Hi,
>>> I am testing intel 16 compilers under mac OS, and notice that options
>>> handling for all past and current versions of petsc is broken in fortran
>>> (options are not parsed).
>>> I narrowed it down to *argc at start.c:168 always being 0 when intel 16 is
>>> used (but taking the right value using intel 15 or gcc 5), but I can’t find
>>> my way through the multiple macros to figure out what is really the matter…
>>> The problem does not seem to arise under linux with the same compilers.
>>> Any idea of what is going on? Any test I can run to help (I assume that
>>> you don’t have a test box with the latest intel compilers)? Is it a petsc
>>> bug or an intel bug?
>>> I use an up to date pets-dev master, and the configure.log file is
>>> available at
>>> https://filestogeaux.lsu.edu/public/download.php?FILE=bourdin/89329uFByT9
>>> Thanks,
>>> Blaise
>>> Department of Mathematics and Center for Computation & Technology
>>> Louisiana State University, Baton Rouge, LA 70803, USA
>>> Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276
>>> http://www.math.lsu.edu/~bourdin
Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
