[petsc-dev] broken options handling with intel 16.0 compilers on	mac OS
    Satish Balay
    balay at mcs.anl.gov
    Sat Sep 19 10:07:36 CDT 2015
This change is now merged master [Its setup as the prefered mode to
get fortran command line arguments]
Satish
On Wed, 16 Sep 2015, Satish Balay wrote:
> Well - the petscconf.h is identicall for both builds. So the change in
> behavior must be due to some internal changes in ifort on Mac [as you
> say - it works fine on linux]
> Can you try using the branch 'balay/ftn-command_argument' - and see if
> that works for you?
> Satish
> On Wed, 16 Sep 2015, Blaise A Bourdin wrote:
> > Hi Satish,
> > It is at https://filestogeaux.lsu.edu/public/download.php?FILE=bourdin/38806CDddLJ
> > > On Sep 16, 2015, at 10:34 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > Do you have configure.log fr intel-15 compiler - on the same machine?
> > > It would be good to compare petscconf.h between intel-15 and intel-16.
> > bourdin at galerkin:petsc-dev (master)$ diff Darwin-intel15.0-g//include/petscconf.h Darwin-intel16.0-g//include/petscconf.h
> > 85c85
> > < #define PETSC_LIB_DIR "/opt/HPC/petsc-dev/Darwin-intel15.0-g/lib"
> > > #define PETSC_LIB_DIR "/opt/HPC/petsc-dev/Darwin-intel16.0-g/lib"
> > 489c489
> > < #define PETSC_ARCH "Darwin-intel15.0-g"
> > > #define PETSC_ARCH "Darwin-intel16.0-g”
> > Not very exciting!
> > I am attaching the one for intel16
