[petsc-dev] broken options handling with intel 16.0 compilers on mac OS
Jeff Hammond
jeff.science at gmail.com
Thu Sep 17 23:34:36 CDT 2015
Please report this via premier.intel.com.
Jeff
On Wed, Sep 16, 2015 at 11:13 AM, Blaise A Bourdin <bourdin at lsu.edu> wrote:
> Hi,
> I am testing intel 16 compilers under mac OS, and notice that options
> handling for all past and current versions of petsc is broken in fortran
> (options are not parsed).
> I narrowed it down to *argc at start.c:168 always being 0 when intel 16 is
> used (but taking the right value using intel 15 or gcc 5), but I can’t find
> my way through the multiple macros to figure out what is really the matter…
> The problem does not seem to arise under linux with the same compilers.
> Any idea of what is going on? Any test I can run to help (I assume that
> you don’t have a test box with the latest intel compilers)? Is it a petsc
> bug or an intel bug?
> I use an up to date pets-dev master, and the configure.log file is
> available at
> https://filestogeaux.lsu.edu/public/download.php?FILE=bourdin/89329uFByT9
> Thanks,
> Blaise
> Department of Mathematics and Center for Computation & Technology
> Louisiana State University, Baton Rouge, LA 70803, USA
> Tel. +1 (225) 578 1612, Fax +1 (225) 578 4276
> http://www.math.lsu.edu/~bourdin
Jeff Hammond
http://jeffhammond.github.io/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150918/420f233d/attachment.html>
