[petsc-dev] broken options handling with intel 16.0 compilers on	mac OS
    Satish Balay
    balay at mcs.anl.gov
    Wed Sep 16 14:25:57 CDT 2015
Well - the petscconf.h is identicall for both builds. So the change in
behavior must be due to some internal changes in ifort on Mac [as you
say - it works fine on linux]
Can you try using the branch 'balay/ftn-command_argument' - and see if
that works for you?
Satish
On Wed, 16 Sep 2015, Blaise A Bourdin wrote:
> Hi Satish,
> It is at https://filestogeaux.lsu.edu/public/download.php?FILE=bourdin/38806CDddLJ
> > On Sep 16, 2015, at 10:34 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > Do you have configure.log fr intel-15 compiler - on the same machine?
> > It would be good to compare petscconf.h between intel-15 and intel-16.
> bourdin at galerkin:petsc-dev (master)$ diff Darwin-intel15.0-g//include/petscconf.h Darwin-intel16.0-g//include/petscconf.h
> 85c85
> < #define PETSC_LIB_DIR "/opt/HPC/petsc-dev/Darwin-intel15.0-g/lib"
> > #define PETSC_LIB_DIR "/opt/HPC/petsc-dev/Darwin-intel16.0-g/lib"
> 489c489
> < #define PETSC_ARCH "Darwin-intel15.0-g"
> > #define PETSC_ARCH "Darwin-intel16.0-g”
> Not very exciting!
> I am attaching the one for intel16
