[petsc-dev] broken options handling with intel 16.0 compilers	on	mac OS
    Blaise A Bourdin
    bourdin at lsu.edu
    Wed Sep 16 11:30:58 CDT 2015
Hi Satish,
It is at https://filestogeaux.lsu.edu/public/download.php?FILE=bourdin/38806CDddLJ
> On Sep 16, 2015, at 10:34 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> Do you have configure.log fr intel-15 compiler - on the same machine?
> It would be good to compare petscconf.h between intel-15 and intel-16.
bourdin at galerkin:petsc-dev (master)$ diff Darwin-intel15.0-g//include/petscconf.h Darwin-intel16.0-g//include/petscconf.h
85c85
< #define PETSC_LIB_DIR "/opt/HPC/petsc-dev/Darwin-intel15.0-g/lib"
> #define PETSC_LIB_DIR "/opt/HPC/petsc-dev/Darwin-intel16.0-g/lib"
489c489
< #define PETSC_ARCH "Darwin-intel15.0-g"
> #define PETSC_ARCH "Darwin-intel16.0-g”
Not very exciting!
I am attaching the one for intel16
Desc: petscconf.h
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150916/1f79c5bf/attachment.obj>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150916/1f79c5bf/attachment.txt>
