[petsc-dev] broken options handling with intel 16.0 compilers on	mac OS
    Satish Balay
    balay at mcs.anl.gov
    Wed Sep 16 10:34:58 CDT 2015
Do you have configure.log fr intel-15 compiler - on the same machine?
It would be good to compare petscconf.h between intel-15 and intel-16.
Satish
On Wed, 16 Sep 2015, Blaise A Bourdin wrote:
> Hi,
> I am testing intel 16 compilers under mac OS, and notice that options handling for all past and current versions of petsc is broken in fortran (options are not parsed).
> I narrowed it down to *argc at start.c:168 always being 0 when intel 16 is used (but taking the right value using intel 15 or gcc 5), but I can’t find my way through the multiple macros to figure out what is really the matter…
> The problem does not seem to arise under linux with the same compilers.
> Any idea of what is going on? Any test I can run to help (I assume that you don’t have a test box with the latest intel compilers)? Is it a petsc bug or an intel bug?
> I use an up to date pets-dev master, and the configure.log file is available at https://filestogeaux.lsu.edu/public/download.php?FILE=bourdin/89329uFByT9
> Thanks,
> Blaise
