[petsc-dev] PETSc blame digest (next) 2015-09-08
    Jed Brown
    jed at jedbrown.org
    Tue Sep  8 09:12:38 CDT 2015
This code has been in PETSc for 6 years.  Did it just become a problem
or were these warnings suppressed?  Is this a useful mode?  Changing the
code to initialize with a bunch of statements makes the code longer,
more redundant, and harder to read, so I'm reluctant to change it unless
someone cares.
PETSc checkBuilds <petsc-checkbuilds at mcs.anl.gov> writes:
> Dear PETSc developer,
> This email contains listings of contributions attributed to you by
> `git blame` that caused compiler errors or warnings in PETSc automated
> testing.  Follow the links to see the full log files. Please attempt to fix
> the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are unable
> to resolve the issues.
> Thanks,
>   The PETSc development team
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/252c3e4
> Add linear acoustics to FV solver
>   src/ts/examples/tutorials/ex9.c:1071
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/examples_next_arch-linux-c89_thrash.log]
>       /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex9.c:1071:10: warning: initializer element is not computable at load time
>   src/ts/examples/tutorials/ex9.c:1154
>       /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex9.c:1154:10: warning: initializer element is not computable at load time
>   src/ts/examples/tutorials/ex9.c:768
>       /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex9.c:768:5: warning: initializer element is not computable at load time
>   src/ts/examples/tutorials/ex9.c:769
>       /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex9.c:769:17: warning: initializer element is not computable at load time
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/26db4db
> Add prototype multiphysics example with analytic Jacobians
>   src/snes/examples/tutorials/ex28.c:143
>       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex28.c:143:5: warning: initializer element is not computable at load time
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/28c2760
> Add example multigrid solver for hydrostatic ice sheet flow
>   src/snes/examples/tutorials/ex48.c:1236
>       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:1236:15: warning: initializer element is not computable at load time
>   src/snes/examples/tutorials/ex48.c:1237
>       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:1237:46: warning: initializer element is not computable at load time
>   src/snes/examples/tutorials/ex48.c:1238
>       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:1238:46: warning: initializer element is not computable at load time
>   src/snes/examples/tutorials/ex48.c:1239
>       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:1239:46: warning: initializer element is not computable at load time
>   src/snes/examples/tutorials/ex48.c:188
>       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:188:87: warning: ISO C90 does not support 'static' or type qualifiers in parameter array declarators [-Wpedantic]
>       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:188:148: warning: ISO C90 does not support 'static' or type qualifiers in parameter array declarators [-Wpedantic]
>       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:188:117: warning: ISO C90 does not support 'static' or type qualifiers in parameter array declarators [-Wpedantic]
>   src/snes/examples/tutorials/ex48.c:190
>       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:190:3: warning: initializer element is not computable at load time
>   src/snes/examples/tutorials/ex48.c:191
>       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:191:3: warning: initializer element is not computable at load time
>   src/snes/examples/tutorials/ex48.c:266
>       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:266:21: warning: initializer element is not computable at load time
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/3b50ffb
> Flesh out 1-D high-resolution finite volume example
>   src/ts/examples/tutorials/ex9.c:770
>       /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex9.c:770:5: warning: initializer element is not computable at load time
>   src/ts/examples/tutorials/ex9.c:906
>       /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex9.c:906:10: warning: initializer element is not computable at load time
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/7570185
> Fix ex48 for complex, explicitly set the "component" field of MatStencil
>   src/snes/examples/tutorials/ex48.c:269
>       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:269:31: warning: initializer element is not computable at load time
>   src/snes/examples/tutorials/ex48.c:270
>       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:270:31: warning: initializer element is not computable at load time
>   src/snes/examples/tutorials/ex48.c:271
>       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:271:31: warning: initializer element is not computable at load time
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/7d9bd58
> snes ex48 updates
>   src/snes/examples/tutorials/ex48.c:272
>       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:272:31: warning: initializer element is not computable at load time
>   src/snes/examples/tutorials/ex48.c:273
>       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:273:31: warning: initializer element is not computable at load time
>   src/snes/examples/tutorials/ex48.c:727
>       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:727:55: warning: ISO C90 does not support 'static' or type qualifiers in parameter array declarators [-Wpedantic]
>       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:727:216: warning: ISO C90 does not support 'static' or type qualifiers in parameter array declarators [-Wpedantic]
>       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:727:122: warning: ISO C90 does not support 'static' or type qualifiers in parameter array declarators [-Wpedantic]
>       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:727:247: warning: ISO C90 does not support 'static' or type qualifiers in parameter array declarators [-Wpedantic]
>       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:727:91: warning: ISO C90 does not support 'static' or type qualifiers in parameter array declarators [-Wpedantic]
>   src/snes/examples/tutorials/ex48.c:820
>       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:820:13: warning: initializer element is not computable at load time
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/8213a6b
> snes ex28 (multi-physics assembly): fix scaling, use more interesting and stable "physics"
>   src/snes/examples/tutorials/ex28.c:150
>       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex28.c:150:7: warning: initializer element is not computable at load time
>   src/snes/examples/tutorials/ex28.c:168
>       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex28.c:168:5: warning: initializer element is not computable at load time
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/864d954
> Make a Brusselator in 1D
>   src/ts/examples/tutorials/ex25.c:254
>       /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex25.c:254:7: warning: initializer element is not computable at load time
>   src/ts/examples/tutorials/ex25.c:257
>       /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex25.c:257:7: warning: initializer element is not computable at load time
>   src/ts/examples/tutorials/ex25.c:259
>       /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex25.c:259:7: warning: initializer element is not computable at load time
>   src/ts/examples/tutorials/ex25.c:260
>       /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex25.c:260:42: warning: initializer element is not computable at load time
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/9406ea4
> New features in 1D FV example
>   src/ts/examples/tutorials/ex9.c:771
>       /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex9.c:771:17: warning: initializer element is not computable at load time
>   src/ts/examples/tutorials/ex9.c:977
>       /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex9.c:977:10: warning: initializer element is not computable at load time
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/afcb2eb
> Make petscimpl.h private
>   include/petsc/private/petscimpl.h:346
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-gcc-absoft_churn.log]
>       /sandbox/petsc/petsc.clone/include/petsc/private/petscimpl.h:346:4: warning: statement has no effect [-Wunused-value]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-gcc-pgf90_grind.log]
>       /sandbox/petsc/petsc.clone-2/include/petsc/private/petscimpl.h:346:3: warning: statement with no effect [-Wunused-value]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-pkgs-valgrind_grind.log]
>       /sandbox/petsc/petsc.clone/include/petsc/private/petscimpl.h:346:3: warning: statement with no effect [-Wunused-value]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-dbg-quad_churn.log]
>       /sandbox/petsc/petsc.clone-3/include/petsc/private/petscimpl.h:346:3: warning: statement with no effect [-Wunused-value]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-pkgs-64idx_thrash.log]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-uni_crush.log]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-pkgs-threadcomm_thrash.log]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-gcc-ifc-cmplx_crank.log]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-pkgs-opt_crank.log]
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-opt-cxx-quad_cg.log]
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/f1c9992
> PetscInitialize/TS: test multiple calls in (bad) convergnce study
>   src/ts/examples/tests/ex25.c:278
>       /sandbox/petsc/petsc.clone-2/src/ts/examples/tests/ex25.c:278:7: warning: initializer element is not computable at load time
>   src/ts/examples/tests/ex25.c:281
>       /sandbox/petsc/petsc.clone-2/src/ts/examples/tests/ex25.c:281:7: warning: initializer element is not computable at load time
>   src/ts/examples/tests/ex25.c:283
>       /sandbox/petsc/petsc.clone-2/src/ts/examples/tests/ex25.c:283:7: warning: initializer element is not computable at load time
>   src/ts/examples/tests/ex25.c:284
>       /sandbox/petsc/petsc.clone-2/src/ts/examples/tests/ex25.c:284:42: warning: initializer element is not computable at load time
> To opt-out from receiving these messages - send a request to petsc-dev at mcs.anl.gov.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150908/76da2eef/attachment.sig>
