[petsc-dev] PETSc blame digest (next) 2015-09-08
    Satish Balay
    balay at mcs.anl.gov
    Tue Sep  8 11:08:42 CDT 2015
Looks like sometimes when the main build fails - all the examples will
fail - trigerring such e-mails..
http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/filtered-make_next_arch-linux-c89_thrash.log
---- ERRORS ----
          CC arch-linux-c89/obj/src/ksp/pc/impls/telescope/telescope_dmda.o
/sandbox/petsc/petsc.clone-2/src/ksp/pc/impls/telescope/telescope.c: In function ‘PCTelescopeMatCreate_default’:
/sandbox/petsc/petsc.clone-2/src/ksp/pc/impls/telescope/telescope.c:210:5: error: expected expression before ‘/’ token
     //ierr = MatCreateMPIMatConcatenateSeqMat(subcomm,Blocal,PETSC_DECIDE,reuse,&Bred);CHKERRQ(ierr);
Satish
On Tue, 8 Sep 2015, Jed Brown wrote:
> This code has been in PETSc for 6 years.  Did it just become a problem
> or were these warnings suppressed?  Is this a useful mode?  Changing the
> code to initialize with a bunch of statements makes the code longer,
> more redundant, and harder to read, so I'm reluctant to change it unless
> someone cares.
> PETSc checkBuilds <petsc-checkbuilds at mcs.anl.gov> writes:
> > Dear PETSc developer,
> > This email contains listings of contributions attributed to you by
> > `git blame` that caused compiler errors or warnings in PETSc automated
> > testing.  Follow the links to see the full log files. Please attempt to fix
> > the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are unable
> > to resolve the issues.
> > Thanks,
> >   The PETSc development team
> > warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/252c3e4
> > Add linear acoustics to FV solver
> >   src/ts/examples/tutorials/ex9.c:1071
> >     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/examples_next_arch-linux-c89_thrash.log]
> >       /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex9.c:1071:10: warning: initializer element is not computable at load time
> >   src/ts/examples/tutorials/ex9.c:1154
> >       /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex9.c:1154:10: warning: initializer element is not computable at load time
> >   src/ts/examples/tutorials/ex9.c:768
> >       /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex9.c:768:5: warning: initializer element is not computable at load time
> >   src/ts/examples/tutorials/ex9.c:769
> >       /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex9.c:769:17: warning: initializer element is not computable at load time
> > warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/26db4db
> > Add prototype multiphysics example with analytic Jacobians
> >   src/snes/examples/tutorials/ex28.c:143
> >       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex28.c:143:5: warning: initializer element is not computable at load time
> > warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/28c2760
> > Add example multigrid solver for hydrostatic ice sheet flow
> >   src/snes/examples/tutorials/ex48.c:1236
> >       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:1236:15: warning: initializer element is not computable at load time
> >   src/snes/examples/tutorials/ex48.c:1237
> >       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:1237:46: warning: initializer element is not computable at load time
> >   src/snes/examples/tutorials/ex48.c:1238
> >       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:1238:46: warning: initializer element is not computable at load time
> >   src/snes/examples/tutorials/ex48.c:1239
> >       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:1239:46: warning: initializer element is not computable at load time
> >   src/snes/examples/tutorials/ex48.c:188
> >       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:188:87: warning: ISO C90 does not support 'static' or type qualifiers in parameter array declarators [-Wpedantic]
> >       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:188:148: warning: ISO C90 does not support 'static' or type qualifiers in parameter array declarators [-Wpedantic]
> >       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:188:117: warning: ISO C90 does not support 'static' or type qualifiers in parameter array declarators [-Wpedantic]
> >   src/snes/examples/tutorials/ex48.c:190
> >       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:190:3: warning: initializer element is not computable at load time
> >   src/snes/examples/tutorials/ex48.c:191
> >       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:191:3: warning: initializer element is not computable at load time
> >   src/snes/examples/tutorials/ex48.c:266
> >       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:266:21: warning: initializer element is not computable at load time
> > warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/3b50ffb
> > Flesh out 1-D high-resolution finite volume example
> >   src/ts/examples/tutorials/ex9.c:770
> >       /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex9.c:770:5: warning: initializer element is not computable at load time
> >   src/ts/examples/tutorials/ex9.c:906
> >       /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex9.c:906:10: warning: initializer element is not computable at load time
> > warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/7570185
> > Fix ex48 for complex, explicitly set the "component" field of MatStencil
> >   src/snes/examples/tutorials/ex48.c:269
> >       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:269:31: warning: initializer element is not computable at load time
> >   src/snes/examples/tutorials/ex48.c:270
> >       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:270:31: warning: initializer element is not computable at load time
> >   src/snes/examples/tutorials/ex48.c:271
> >       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:271:31: warning: initializer element is not computable at load time
> > warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/7d9bd58
> > snes ex48 updates
> >   src/snes/examples/tutorials/ex48.c:272
> >       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:272:31: warning: initializer element is not computable at load time
> >   src/snes/examples/tutorials/ex48.c:273
> >       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:273:31: warning: initializer element is not computable at load time
> >   src/snes/examples/tutorials/ex48.c:727
> >       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:727:55: warning: ISO C90 does not support 'static' or type qualifiers in parameter array declarators [-Wpedantic]
> >       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:727:216: warning: ISO C90 does not support 'static' or type qualifiers in parameter array declarators [-Wpedantic]
> >       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:727:122: warning: ISO C90 does not support 'static' or type qualifiers in parameter array declarators [-Wpedantic]
> >       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:727:247: warning: ISO C90 does not support 'static' or type qualifiers in parameter array declarators [-Wpedantic]
> >       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:727:91: warning: ISO C90 does not support 'static' or type qualifiers in parameter array declarators [-Wpedantic]
> >   src/snes/examples/tutorials/ex48.c:820
> >       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:820:13: warning: initializer element is not computable at load time
> > warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/8213a6b
> > snes ex28 (multi-physics assembly): fix scaling, use more interesting and stable "physics"
> >   src/snes/examples/tutorials/ex28.c:150
> >       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex28.c:150:7: warning: initializer element is not computable at load time
> >   src/snes/examples/tutorials/ex28.c:168
> >       /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex28.c:168:5: warning: initializer element is not computable at load time
> > warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/864d954
> > Make a Brusselator in 1D
> >   src/ts/examples/tutorials/ex25.c:254
> >       /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex25.c:254:7: warning: initializer element is not computable at load time
> >   src/ts/examples/tutorials/ex25.c:257
> >       /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex25.c:257:7: warning: initializer element is not computable at load time
> >   src/ts/examples/tutorials/ex25.c:259
> >       /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex25.c:259:7: warning: initializer element is not computable at load time
> >   src/ts/examples/tutorials/ex25.c:260
> >       /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex25.c:260:42: warning: initializer element is not computable at load time
> > warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/9406ea4
> > New features in 1D FV example
> >   src/ts/examples/tutorials/ex9.c:771
> >       /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex9.c:771:17: warning: initializer element is not computable at load time
> >   src/ts/examples/tutorials/ex9.c:977
> >       /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex9.c:977:10: warning: initializer element is not computable at load time
> > warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/afcb2eb
> > Make petscimpl.h private
> >   include/petsc/private/petscimpl.h:346
> >     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-gcc-absoft_churn.log]
> >       /sandbox/petsc/petsc.clone/include/petsc/private/petscimpl.h:346:4: warning: statement has no effect [-Wunused-value]
> >     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-gcc-pgf90_grind.log]
> >       /sandbox/petsc/petsc.clone-2/include/petsc/private/petscimpl.h:346:3: warning: statement with no effect [-Wunused-value]
> >     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-pkgs-valgrind_grind.log]
> >       /sandbox/petsc/petsc.clone/include/petsc/private/petscimpl.h:346:3: warning: statement with no effect [-Wunused-value]
> >     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-dbg-quad_churn.log]
> >       /sandbox/petsc/petsc.clone-3/include/petsc/private/petscimpl.h:346:3: warning: statement with no effect [-Wunused-value]
> >     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-pkgs-64idx_thrash.log]
> >     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-uni_crush.log]
> >     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-pkgs-threadcomm_thrash.log]
> >     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-gcc-ifc-cmplx_crank.log]
> >     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-pkgs-opt_crank.log]
> >     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-opt-cxx-quad_cg.log]
> > warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/f1c9992
> > PetscInitialize/TS: test multiple calls in (bad) convergnce study
> >   src/ts/examples/tests/ex25.c:278
> >       /sandbox/petsc/petsc.clone-2/src/ts/examples/tests/ex25.c:278:7: warning: initializer element is not computable at load time
> >   src/ts/examples/tests/ex25.c:281
> >       /sandbox/petsc/petsc.clone-2/src/ts/examples/tests/ex25.c:281:7: warning: initializer element is not computable at load time
> >   src/ts/examples/tests/ex25.c:283
> >       /sandbox/petsc/petsc.clone-2/src/ts/examples/tests/ex25.c:283:7: warning: initializer element is not computable at load time
> >   src/ts/examples/tests/ex25.c:284
> >       /sandbox/petsc/petsc.clone-2/src/ts/examples/tests/ex25.c:284:42: warning: initializer element is not computable at load time
> > To opt-out from receiving these messages - send a request to petsc-dev at mcs.anl.gov.
