[petsc-dev] [petsc-checkbuilds] PETSc blame digest (next)	2015-09-06
    Barry Smith
    bsmith at mcs.anl.gov
    Sun Sep  6 14:12:16 CDT 2015
  Don't worry about these. I'm going to make a new test rule _C99 for examples that require C99.
  Barry
> On Sep 6, 2015, at 9:00 AM, PETSc checkBuilds <petsc-checkbuilds at mcs.anl.gov> wrote:
> Dear PETSc developer,
> This email contains listings of contributions attributed to you by
> `git blame` that caused compiler errors or warnings in PETSc automated
> testing.  Follow the links to see the full log files. Please attempt to fix
> the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are unable
> to resolve the issues.
> Thanks,
>  The PETSc development team
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/252c3e4
> Add linear acoustics to FV solver
>  src/ts/examples/tutorials/ex9.c:1071
>    [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/06/examples_next_arch-linux-c89_thrash.log]
>      /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex9.c:1071:10: warning: initializer element is not computable at load time
>  src/ts/examples/tutorials/ex9.c:1154
>      /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex9.c:1154:10: warning: initializer element is not computable at load time
>  src/ts/examples/tutorials/ex9.c:768
>      /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex9.c:768:5: warning: initializer element is not computable at load time
>  src/ts/examples/tutorials/ex9.c:769
>      /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex9.c:769:17: warning: initializer element is not computable at load time
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/26db4db
> Add prototype multiphysics example with analytic Jacobians
>  src/snes/examples/tutorials/ex28.c:143
>      /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex28.c:143:5: warning: initializer element is not computable at load time
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/28c2760
> Add example multigrid solver for hydrostatic ice sheet flow
>  src/snes/examples/tutorials/ex48.c:1236
>      /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:1236:15: warning: initializer element is not computable at load time
>  src/snes/examples/tutorials/ex48.c:1237
>      /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:1237:46: warning: initializer element is not computable at load time
>  src/snes/examples/tutorials/ex48.c:1238
>      /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:1238:46: warning: initializer element is not computable at load time
>  src/snes/examples/tutorials/ex48.c:1239
>      /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:1239:46: warning: initializer element is not computable at load time
>  src/snes/examples/tutorials/ex48.c:188
>      /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:188:148: warning: ISO C90 does not support 'static' or type qualifiers in parameter array declarators [-Wpedantic]
>      /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:188:117: warning: ISO C90 does not support 'static' or type qualifiers in parameter array declarators [-Wpedantic]
>      /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:188:87: warning: ISO C90 does not support 'static' or type qualifiers in parameter array declarators [-Wpedantic]
>  src/snes/examples/tutorials/ex48.c:190
>      /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:190:3: warning: initializer element is not computable at load time
>  src/snes/examples/tutorials/ex48.c:191
>      /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:191:3: warning: initializer element is not computable at load time
>  src/snes/examples/tutorials/ex48.c:266
>      /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:266:21: warning: initializer element is not computable at load time
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/3b50ffb
> Flesh out 1-D high-resolution finite volume example
>  src/ts/examples/tutorials/ex9.c:770
>      /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex9.c:770:5: warning: initializer element is not computable at load time
>  src/ts/examples/tutorials/ex9.c:906
>      /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex9.c:906:10: warning: initializer element is not computable at load time
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/7570185
> Fix ex48 for complex, explicitly set the "component" field of MatStencil
>  src/snes/examples/tutorials/ex48.c:269
>      /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:269:31: warning: initializer element is not computable at load time
>  src/snes/examples/tutorials/ex48.c:270
>      /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:270:31: warning: initializer element is not computable at load time
>  src/snes/examples/tutorials/ex48.c:271
>      /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:271:31: warning: initializer element is not computable at load time
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/7d9bd58
> snes ex48 updates
>  src/snes/examples/tutorials/ex48.c:272
>      /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:272:31: warning: initializer element is not computable at load time
>  src/snes/examples/tutorials/ex48.c:273
>      /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:273:31: warning: initializer element is not computable at load time
>  src/snes/examples/tutorials/ex48.c:727
>      /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:727:247: warning: ISO C90 does not support 'static' or type qualifiers in parameter array declarators [-Wpedantic]
>      /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:727:216: warning: ISO C90 does not support 'static' or type qualifiers in parameter array declarators [-Wpedantic]
>      /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:727:91: warning: ISO C90 does not support 'static' or type qualifiers in parameter array declarators [-Wpedantic]
>      /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:727:122: warning: ISO C90 does not support 'static' or type qualifiers in parameter array declarators [-Wpedantic]
>      /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:727:55: warning: ISO C90 does not support 'static' or type qualifiers in parameter array declarators [-Wpedantic]
>  src/snes/examples/tutorials/ex48.c:820
>      /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex48.c:820:13: warning: initializer element is not computable at load time
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/8213a6b
> snes ex28 (multi-physics assembly): fix scaling, use more interesting and stable "physics"
>  src/snes/examples/tutorials/ex28.c:150
>      /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex28.c:150:7: warning: initializer element is not computable at load time
>  src/snes/examples/tutorials/ex28.c:168
>      /sandbox/petsc/petsc.clone-2/src/snes/examples/tutorials/ex28.c:168:5: warning: initializer element is not computable at load time
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/864d954
> Make a Brusselator in 1D
>  src/ts/examples/tutorials/ex25.c:254
>      /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex25.c:254:7: warning: initializer element is not computable at load time
>  src/ts/examples/tutorials/ex25.c:257
>      /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex25.c:257:7: warning: initializer element is not computable at load time
>  src/ts/examples/tutorials/ex25.c:259
>      /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex25.c:259:7: warning: initializer element is not computable at load time
>  src/ts/examples/tutorials/ex25.c:260
>      /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex25.c:260:42: warning: initializer element is not computable at load time
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/9406ea4
> New features in 1D FV example
>  src/ts/examples/tutorials/ex9.c:771
>      /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex9.c:771:17: warning: initializer element is not computable at load time
>  src/ts/examples/tutorials/ex9.c:977
>      /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex9.c:977:10: warning: initializer element is not computable at load time
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/f1c9992
> PetscInitialize/TS: test multiple calls in (bad) convergnce study
>  src/ts/examples/tests/ex25.c:278
>      /sandbox/petsc/petsc.clone-2/src/ts/examples/tests/ex25.c:278:7: warning: initializer element is not computable at load time
>  src/ts/examples/tests/ex25.c:281
>      /sandbox/petsc/petsc.clone-2/src/ts/examples/tests/ex25.c:281:7: warning: initializer element is not computable at load time
>  src/ts/examples/tests/ex25.c:283
>      /sandbox/petsc/petsc.clone-2/src/ts/examples/tests/ex25.c:283:7: warning: initializer element is not computable at load time
>  src/ts/examples/tests/ex25.c:284
>      /sandbox/petsc/petsc.clone-2/src/ts/examples/tests/ex25.c:284:42: warning: initializer element is not computable at load time
> To opt-out from receiving these messages - send a request to petsc-dev at mcs.anl.gov.
