[petsc-dev] [petsc-users] MatGetSubMatrices or VecCreateGhost
hong at aspiritech.org
Fri Oct 16 13:44:52 CDT 2015
I'm writing MatTransposeMatMult_MPIDense_MPIDense() without elemental now
(almost done).
It would be nice to have MatConvert() between MPIDense and elemental [VC,*]
- it seems we use elemental default (2D?).
Jed: do you know how to set [VC,*] for MatConvert_mpidense_elemental?
If we have MatConvert() without data movement, then we gain all dense
operations supported by elemental.
Hong
On Fri, Oct 16, 2015 at 1:29 PM, Jed Brown <jed at jedbrown.org> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
> > We don't have a parallel
> Elemental makes sense here; the 2D distribution will scale much better.
> Note that MatTransposeMatMult_MPIDense_MPIDense is fairly trivial and
> very useful for tall-skinny matrices, which is the case in which the
> MPIDense distribution ([VC,*] in Elemental vernacular) actually makes
> sense.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20151016/51d33adb/attachment.html>
