[petsc-dev] [petsc-users] MatGetSubMatrices or VecCreateGhost
Jed Brown
jed at jedbrown.org
Fri Oct 16 17:19:11 CDT 2015
"hong at aspiritech.org" <hong at aspiritech.org> writes:
> I'm writing MatTransposeMatMult_MPIDense_MPIDense() without elemental now
> (almost done).
> It would be nice to have MatConvert() between MPIDense and elemental [VC,*]
> - it seems we use elemental default (2D?).
Yeah.
> Jed: do you know how to set [VC,*] for MatConvert_mpidense_elemental?
Yes, see the El::MC,El::MR template parameters to DistMatrix.
However, we should probably update the Elemental interface to use the
newish Elemental C bindings, so the interface doesn't need to be C++.
> If we have MatConvert() without data movement, then we gain all dense
> operations supported by elemental.
True.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20151016/60b6c4d2/attachment.sig>
