[petsc-dev] Mac OS X El Capitan does not propagate	DYLD_LIBRARY_PATH from parent process
    Satish Balay
    balay at mcs.anl.gov
    Wed Oct  7 15:43:56 CDT 2015
Well both invocations are weeding out DYLD_LIBRARY_PATH from env list.
Satish
balay at imav^~/junk $ cat env-test.py
#!/usr/bin/env python
import os
if 'FOOBAR' in os.environ:
  print 'FOOBAR:', os.environ['FOOBAR']
else:
  print 'FOOBAR not in env'
if 'DYLD_LIBRARY_PATH' in os.environ:
  print 'DYLD_LIBRARY_PATH:', os.environ['DYLD_LIBRARY_PATH']
else:
  print 'DYLD_LIBRARY_PATH not in env'
balay at imav^~/junk $ export DYLD_LIBRARY_PATH=foobar
balay at imav^~/junk $ export FOOBAR=foobar
balay at imav^~/junk $ ./env-test.py
FOOBAR: foobar
balay at imav^~/junk $ python env-test.py
FOOBAR: foobar
On Wed, 7 Oct 2015, Jed Brown wrote:
> "Andrs, David" <david.andrs at inl.gov> writes:
> > It looks like it when the compiler is invoked from an interpreter (like
> > bash or python). If we run clang from the command line directly, it works
> > fine.
> From the documentation page, it sounds like
> DYLD_LIBRARY_PATH=x ./foo.py
> will not propagate the variable, but
> DYLD_LIBRARY_PATH=x /usr/bin/python foo.py
> will propagate it because /usr/bin/python is not a script (starting with
> #!).  Is this true?
> How are you invoking the compiler from Python?  (In particular, is
> Python calling execve directly or is it passing a command line to a
> shell to expand and execute?)
