[petsc-dev] Mac OS X El Capitan does not propagate DYLD_LIBRARY_PATH from parent process
Jed Brown
jed at jedbrown.org
Wed Oct 7 15:32:42 CDT 2015
"Andrs, David" <david.andrs at inl.gov> writes:
> It looks like it when the compiler is invoked from an interpreter (like
> bash or python). If we run clang from the command line directly, it works
> fine.
From the documentation page, it sounds like
DYLD_LIBRARY_PATH=x ./foo.py
will not propagate the variable, but
DYLD_LIBRARY_PATH=x /usr/bin/python foo.py
will propagate it because /usr/bin/python is not a script (starting with
#!). Is this true?
How are you invoking the compiler from Python? (In particular, is
Python calling execve directly or is it passing a command line to a
shell to expand and execute?)
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20151007/1b0d112c/attachment.sig>
