[petsc-dev] Mac OS X El Capitan does not propagate DYLD_LIBRARY_PATH from parent process
Satish Balay
balay at mcs.anl.gov
Wed Oct 7 15:52:47 CDT 2015
[reply to Todd's question 'does the #! line make a difference']
It does not.
Satish
balay at imav^~/junk $ cat env-test.py
import os
if 'FOOBAR' in os.environ:
print 'FOOBAR:', os.environ['FOOBAR']
else:
print 'FOOBAR not in env'
if 'DYLD_LIBRARY_PATH' in os.environ:
print 'DYLD_LIBRARY_PATH:', os.environ['DYLD_LIBRARY_PATH']
else:
print 'DYLD_LIBRARY_PATH not in env'
balay at imav^~/junk $ python env-test.py
FOOBAR: foobar
On Wed, 7 Oct 2015, Satish Balay wrote:
> Well both invocations are weeding out DYLD_LIBRARY_PATH from env list.
> Satish
> #!/usr/bin/env python
> import os
> else:
> else:
> balay at imav^~/junk $ export DYLD_LIBRARY_PATH=foobar
> balay at imav^~/junk $ export FOOBAR=foobar
> balay at imav^~/junk $ ./env-test.py
> FOOBAR: foobar
> FOOBAR: foobar
> On Wed, 7 Oct 2015, Jed Brown wrote:
> > "Andrs, David" <david.andrs at inl.gov> writes:
> > > It looks like it when the compiler is invoked from an interpreter (like
> > > bash or python). If we run clang from the command line directly, it works
> > > fine.
> > From the documentation page, it sounds like
> > DYLD_LIBRARY_PATH=x ./foo.py
> > will not propagate the variable, but
> > DYLD_LIBRARY_PATH=x /usr/bin/python foo.py
> > will propagate it because /usr/bin/python is not a script (starting with
> > #!). Is this true?
> > How are you invoking the compiler from Python? (In particular, is
> > Python calling execve directly or is it passing a command line to a
> > shell to expand and execute?)
