[petsc-dev] ASPIN and SNESSetType
Thu Oct 1 14:28:07 CDT 2015
  Matt is at least partially right, having this as a SNESType is questionable. It is actually a specific nonlinear preconditioner PLUS a specific set of options for the NewtonLS SNES method. I also understand why Peter did it this way because there is no clean "other way" to provide this functionality that is not ad hoc.
  I think the correct short term fix is to add a SNESDestroy_ASPIN() that does delete the npc and then calls the SNESDestroy_NewtonLS()
  Stefano,
    Are you willing to make a pull request or patch to do this?
   Thanks for letting us know about this problem
  Barry
> On Oct 1, 2015, at 12:43 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Oct 1, 2015 at 7:42 AM, Stefano Zampini <stefano.zampini at gmail.com> wrote:
> I just noticed that the behaviour of a code like this
> SNESSetType(snes,SNESASPIN)
> SNESSetFromOptions(snes)
> is not the same as
> SNESSetType(snes,SNESNEWTONLS)
> when -snes_type newtonls is specified at command line. In both cases, the snes will be of type SNESNEWTONLS, but in the first case, the snes object will also have a nonlinear preconditioner embedded in, since SNESASPIN creates snes->pc, and there's no SNESDestroy_ASPIN.
> What is the correct approach to fix this? Should the nonlinear preconditioner be destroyed by the SNESSetType interface or by the specific implementation of ASPIN?
> I wish Peter had not done it this way. His reason was that a special Jacobian action can be defined for
> Newton -L NASM, but we should just do this with a flag rather than a new SNES type.
>    Matt
> Stefano
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
