[petsc-dev] ASPIN and SNESSetType
Thu Oct 1 12:43:54 CDT 2015
On Thu, Oct 1, 2015 at 7:42 AM, Stefano Zampini <stefano.zampini at gmail.com>
wrote:
> I just noticed that the behaviour of a code like this
> SNESSetType(snes,SNESASPIN)
> SNESSetFromOptions(snes)
> is not the same as
> SNESSetType(snes,SNESNEWTONLS)
> when -snes_type newtonls is specified at command line. In both cases, the
> snes will be of type SNESNEWTONLS, but in the first case, the snes object
> will also have a nonlinear preconditioner embedded in, since SNESASPIN
> creates snes->pc, and there's no SNESDestroy_ASPIN.
> What is the correct approach to fix this? Should the nonlinear
> preconditioner be destroyed by the SNESSetType interface or by the specific
> implementation of ASPIN?
I wish Peter had not done it this way. His reason was that a special
Jacobian action can be defined for
Newton -L NASM, but we should just do this with a flag rather than a new
SNES type.
   Matt
> Stefano
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20151001/51676bbe/attachment.html>
