[petsc-dev] ASPIN and SNESSetType
    Stefano Zampini
    stefano.zampini at gmail.com
    Thu Oct  1 14:30:59 CDT 2015
I'll open a pull request
Il 01/ott/2015 10:28 PM, "Barry Smith" <bsmith at mcs.anl.gov> ha scritto:
>   Matt is at least partially right, having this as a SNESType is
> questionable. It is actually a specific nonlinear preconditioner PLUS a
> specific set of options for the NewtonLS SNES method. I also understand why
> Peter did it this way because there is no clean "other way" to provide this
> functionality that is not ad hoc.
>   I think the correct short term fix is to add a SNESDestroy_ASPIN() that
> does delete the npc and then calls the SNESDestroy_NewtonLS()
>   Stefano,
>     Are you willing to make a pull request or patch to do this?
>    Thanks for letting us know about this problem
>   Barry
> > On Oct 1, 2015, at 12:43 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Thu, Oct 1, 2015 at 7:42 AM, Stefano Zampini <
> stefano.zampini at gmail.com> wrote:
> > I just noticed that the behaviour of a code like this
> > SNESSetType(snes,SNESASPIN)
> > SNESSetFromOptions(snes)
> > is not the same as
> > SNESSetType(snes,SNESNEWTONLS)
> > when -snes_type newtonls is specified at command line. In both cases,
> the snes will be of type SNESNEWTONLS, but in the first case, the snes
> object will also have a nonlinear preconditioner embedded in, since
> SNESASPIN creates snes->pc, and there's no SNESDestroy_ASPIN.
> > What is the correct approach to fix this? Should the nonlinear
> preconditioner be destroyed by the SNESSetType interface or by the specific
> implementation of ASPIN?
> > I wish Peter had not done it this way. His reason was that a special
> Jacobian action can be defined for
> > Newton -L NASM, but we should just do this with a flag rather than a new
> SNES type.
> >    Matt
> > Stefano
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20151001/778161a2/attachment.html>
