[petsc-dev] ASPIN and SNESSetType
Stefano Zampini
stefano.zampini at gmail.com
Thu Oct 1 07:42:19 CDT 2015
I just noticed that the behaviour of a code like this
SNESSetType(snes,SNESASPIN)
SNESSetFromOptions(snes)
is not the same as
SNESSetType(snes,SNESNEWTONLS)
when -snes_type newtonls is specified at command line. In both cases, the
snes will be of type SNESNEWTONLS, but in the first case, the snes object
will also have a nonlinear preconditioner embedded in, since SNESASPIN
creates snes->pc, and there's no SNESDestroy_ASPIN.
What is the correct approach to fix this? Should the nonlinear
preconditioner be destroyed by the SNESSetType interface or by the specific
implementation of ASPIN?
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20151001/656fd303/attachment.html>
