[petsc-dev] Clang configure
Thu Oct 1 11:55:11 CDT 2015
Which clang? log?
I don't see this problem with:
$ clang --version
clang version 3.7.0 (tags/RELEASE_370/final)
Target: x86_64-redhat-linux-gnu
Thread model: posix
However - I do get a bunch of plex warnings though. Attaching make.log
If -Qunused-arguments is required - perhaps it can go into the defaults in compilerOptions.py?
Satish
On Thu, 1 Oct 2015, Matthew Knepley wrote:
> Everything now flat-out fails for me using Clang unless I give
>    -Qunused-arguments
> This is because -fPIC is unrecognized, and this is because Clang
> puts a warning message out on stderr that says some include directory
> was not used.
> Where does this gets fixed? Do we start filtering stderr, which is
> problematic,
> or do we try to detect this particular failure and give a good error
> message?
>    Matt
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20151001/84805bd5/attachment.ksh>
