[petsc-dev] Clang configure
Matthew Knepley
knepley at gmail.com
Thu Oct 1 11:59:14 CDT 2015
On Thu, Oct 1, 2015 at 11:55 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> Which clang? log?
> I don't see this problem with:
> $ clang --version
> clang version 3.7.0 (tags/RELEASE_370/final)
> Target: x86_64-redhat-linux-gnu
> Thread model: posix
master *:~$ clang --version
Apple LLVM version 6.0 (clang-600.0.57) (based on LLVM 3.5svn)
Target: x86_64-apple-darwin13.4.0
Thread model: posix
However - I do get a bunch of plex warnings though. Attaching make.log
> If -Qunused-arguments is required - perhaps it can go into the defaults in
> compilerOptions.py?
That is probably the best place.
Matt
> Satish
> On Thu, 1 Oct 2015, Matthew Knepley wrote:
> > Everything now flat-out fails for me using Clang unless I give
> > -Qunused-arguments
> > This is because -fPIC is unrecognized, and this is because Clang
> > puts a warning message out on stderr that says some include directory
> > was not used.
> > Where does this gets fixed? Do we start filtering stderr, which is
> > problematic,
> > or do we try to detect this particular failure and give a good error
> > message?
> > Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20151001/8542a6f8/attachment.html>
