[petsc-dev] Subject: PETSc nightly blame digest, 2015-03-21
Abhyankar, Shrirang G. abhyshr at mcs.anl.gov
Sun Mar 22 09:29:21 CDT 2015
Fixed in shri/ts-is-for-differential-variables, next, and master. This
blame thingy is a great addition!
Shri
-----Original Message-----
From: petsc-dev mailing list <petsc-dev at mcs.anl.gov>
Date: Sunday, March 22, 2015 at 9:00 AM
To: Shri <abhyshr at mcs.anl.gov>, barry smith <bsmith at mcs.anl.gov>, satish
balay <balay at mcs.anl.gov>
Subject: Subject: PETSc nightly blame digest, 2015-03-21
>Dear PETSc developer,
>This email contains listings of contributions attributed to you by
>`git blame` that caused compiler errors or warnings in PETSc nightly
>build testing.  Warnings are labeled by the machine, PETSC_ARCH, and
>git branch that generated the warnings.  These warnings may be
>missing some context: for the full context, please go to the nightly
>build website [1] and find the corresponding log file: either
>build_(branch)_(PETSC_ARCH)_(machine).log, or
>examples_(branch)_(PETSC_ARCH)_(machine).log.
>Thanks,
>  The PETSc development team
>[1] http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/03/22
>warnings attributed to commit 9c6b16b ts-isdiff: Added code for 2-norm
>and infinite-norm error calculation based only on differential variables
>when an IS for differential equations is set for TS.
>  src/ts/interface/ts.c:5318
>    [grind,arch-linux-gcc-pgf90,next]
>/sandbox/petsc/petsc.clone-2/src/ts/interface/ts.c:5318:21: warning:
>variable 'ierr' set but not used [-Wunused-but-set-variable]
>    [bb-proxy,arch-cuda-double,next]
>/home/balay/petsc.clone/src/ts/interface/ts.c:5318:21: warning: variable
>    [bb-proxy,arch-c-exodus-dbg-builder,next]
>/home/balay/petsc.clone-3/src/ts/interface/ts.c:5318:21: warning:
>    [cg,arch-linux-opt-cxx-quad,next]
>/sandbox/petsc/petsc.clone/src/ts/interface/ts.c:5318:21: warning:
>    [bb-proxy,arch-cuda,next]
>/home/balay/petsc.clone-2/src/ts/interface/ts.c:5318:21: warning:
>    [bb-proxy,arch-viennacl,next]
>/home/balay/petsc.clone-4/src/ts/interface/ts.c:5318:21: warning:
>    [thrash,arch-linux-pkgs-64idx,next]
>/sandbox/petsc/petsc.clone-3/src/ts/interface/ts.c:5318:21: warning:
>    [crush,arch-linux-uni,next]
>    [crank,arch-linux-pkgs-opt,next]
>    [crank,arch-linux-gcc-ifc-cmplx,next]
>    [churn,arch-linux-gcc-absoft,next]
>    [churn,arch-linux-dbg-quad,next]
>    [wii,arch-freebsd-cxx-cmplx-pkgs-dbg,next]
>    [grind,arch-linux-pkgs-valgrind,next]
>    [grind,arch-linux-pkgs-cxx-mlib,next]
>    [thrash,arch-linux-pkgs-threadcomm,next]
