[petsc-dev] Subject: PETSc nightly blame digest, 2015-03-21
Hong hzhang at mcs.anl.gov
Sun Mar 22 09:34:19 CDT 2015
I do not understand what is wrong.
On Sun, Mar 22, 2015 at 9:00 AM, checkBuilds <petsc-dev at mcs.anl.gov> wrote:
> This email contains listings of contributions attributed to you by
> `git blame` that caused compiler errors or warnings in PETSc nightly
> build testing.  Warnings are labeled by the machine, PETSC_ARCH, and
> git branch that generated the warnings.  These warnings may be
> missing some context: for the full context, please go to the nightly
> build website [1] and find the corresponding log file: either
> build_(branch)_(PETSC_ARCH)_(machine).log, or
> examples_(branch)_(PETSC_ARCH)_(machine).log.
> Thanks,
>   The PETSc development team
> [1] http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/03/22
> warnings attributed to commit 180a43e add MatGetInfo_Elemental(). Now KSP
> can be used with elemental matrix.
This is a trivial commit
https://bitbucket.org/petsc/petsc/commits/180a43e4d551e9f28d4b43e03a8758f4024c6a3d
adding an empty function MatGetInfo_Elemental()
>   src/mat/impls/elemental/matelem.cxx:1376
>     [crank,arch-linux-pkgs-opt,next]
> /sandbox/petsc/petsc.clone/src/mat/impls/elemental/matelem.cxx:1376:30:
> note: in expansion of macro 'MPI_NULL_COPY_FN'
> /sandbox/petsc/petsc.clone/src/mat/impls/elemental/matelem.cxx:1376:47:
> note: in expansion of macro 'MPI_NULL_DELETE_FN'
The line 1376 has been in the file for long time -- at least I did not add
it:
   if (Petsc_Elemental_keyval == MPI_KEYVAL_INVALID) {
    ierr =
MPI_Keyval_create(MPI_NULL_COPY_FN,MPI_NULL_DELETE_FN,&Petsc_Elemental_keyval,(void*)0);
Would recent change in other places cause this problem?
Hong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150322/430375e3/attachment.html>
