[petsc-dev] parsing FORTRAN command line on Cray XC40
Stefano Zampini stefano.zampini at gmail.com
Mon Mar 23 02:50:57 CDT 2015
Satish,
thanks. It works now.
Stefano
2015-03-22 20:11 GMT+03:00 Satish Balay <balay at mcs.anl.gov>:
> All of this code [related to fortran command line processing] is old
> hackey.
> Does the following change fix the issue for you?
> diff --git a/config/BuildSystem/config/utilities/fortranCommandLine.py
> b/config/BuildSystem/config/utilities/fortranCommandLine.py
> index 25833a0..ae47da5 100644
> --- a/config/BuildSystem/config/utilities/fortranCommandLine.py
> +++ b/config/BuildSystem/config/utilities/fortranCommandLine.py
> @@ -50,13 +50,13 @@ class Configure(config.base.Configure):
>        self.addDefine('HAVE_NAGF90',1)
>      elif self.functions.check('PXFGETARG', libraries =
> self.compilers.flibs):
>        self.addDefine('HAVE_PXFGETARG',1)
> -    elif self.functions.check('iargc_', libraries = self.compilers.flibs):
> -      self.addDefine('HAVE_BGL_IARGC',1)
>      elif self.functions.check('GETARG at 16', libraries =
>        self.addDefine('USE_NARGS',1)
>        self.addDefine('HAVE_IARG_COUNT_PROGNAME',1)
>      elif self.functions.check('_gfortran_iargc', libraries =
>        self.addDefine('HAVE_GFORTRAN_IARGC',1)
> +    elif self.functions.check('iargc_', libraries = self.compilers.flibs):
> +      self.addDefine('HAVE_BGL_IARGC',1)
>      self.popLanguage()
>      return
> Perhaps there is a way to remove all of this [c] code - and use a
> single fortran routine [that works with all fortran compilers] - to
> process command line args..
> Satish
> On Sun, 22 Mar 2015, Stefano Zampini wrote:
> > command line parsing does not work from FORTRAN programs only, it works
> for
> > C/C++
> > 2015-03-22 12:19 GMT+03:00 Stefano Zampini <stefano.zampini at gmail.com>:
> > > It seems that command line parsing does not work on my personal
> > > installation on a CrayXC40.
> > > Namely, the number of command line arguments is always zero.
> > > Attached a configure.log and the petscconf.h file generated
> > > I'm using the GNU module inside CRAY compiler wrappers but PETSc
> configure
> > > doesn't define  any of  PETSC_HAVE_GFORTRAN_IARGC,
> > > PETSC_HAVE__GFORTRAN_IARGC. Instead, it defines PETSC_HAVE_BGL_IARGC.
> > > I'm working on branch stefano_zampini/pcbddc-adaptive-selection
> > > Stefano
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150323/2a6ee2da/attachment.html>
