[petsc-dev] parsing FORTRAN command line on Cray XC40
    Stefano Zampini
    stefano.zampini at gmail.com
    Sun Mar 22 04:19:22 CDT 2015
It seems that command line parsing does not work on my personal
installation on a CrayXC40.
Namely, the number of command line arguments is always zero.
Attached a configure.log and the petscconf.h file generated
I'm using the GNU module inside CRAY compiler wrappers but PETSc configure
doesn't define  any of  PETSC_HAVE_GFORTRAN_IARGC,
PETSC_HAVE__GFORTRAN_IARGC. Instead, it defines PETSC_HAVE_BGL_IARGC.
I'm working on branch stefano_zampini/pcbddc-adaptive-selection
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150322/51775b4e/attachment.html>
Type: text/x-chdr
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150322/51775b4e/attachment.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150322/51775b4e/attachment-0001.bin>
