[petsc-dev] parsing FORTRAN command line on Cray XC40
    Stefano Zampini
    stefano.zampini at gmail.com
    Sun Mar 22 04:20:45 CDT 2015
command line parsing does not work from FORTRAN programs only, it works for
C/C++
2015-03-22 12:19 GMT+03:00 Stefano Zampini <stefano.zampini at gmail.com>:
> It seems that command line parsing does not work on my personal
> installation on a CrayXC40.
> Namely, the number of command line arguments is always zero.
> Attached a configure.log and the petscconf.h file generated
> I'm using the GNU module inside CRAY compiler wrappers but PETSc configure
> doesn't define  any of  PETSC_HAVE_GFORTRAN_IARGC,
> PETSC_HAVE__GFORTRAN_IARGC. Instead, it defines PETSC_HAVE_BGL_IARGC.
> I'm working on branch stefano_zampini/pcbddc-adaptive-selection
> Stefano
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150322/a3388570/attachment.html>
