[petsc-dev] actually, I think I did find and fix a bug in virs.c:SNESSolve_VINEWTONRSLS() [attached patch]
Barry Smith
bsmith at mcs.anl.gov
Wed Mar 18 16:52:23 CDT 2015
I have pushed a fix to the barry/snes-monitor-vi-residual and next branch.
Note that it is ok for DMDestroyVI() to be called "extra" times.
Barry
> On Mar 18, 2015, at 4:35 PM, Ed Bueler <elbueler at alaska.edu> wrote:
> Barry and Jed --
> Actually, I think I do see a bug that has caused me some problems, namely that when RSLS diverges, stuff is corrupt. This seems to be because DMDestroyVI() was not called when the diverged cause a "break" out of the for loop in SNESSolve_VINEWTONRSLS(). Part of the problem was the indent level. ;-)
> I've decided to follow this advice:
> *For very small changes you can clone the petsc repository, create a new branch on your local repository from master, apply and commit your changes there, and use git format-patch origin/master to create the patch. Send the patch to petsc-dev at mcs.anl.gov.
> The attached should explain itself, but note I branched off of barry/snes-monitor-vi-residual, and thus did
> git format-patch barry/snes-monitor-vi-residual
> to generate the patch.
> Is this an easy to apply form, compared to me being confused about my fork?
> Ed
> Ed Bueler
> Dept of Math and Stat and Geophysical Institute
> University of Alaska Fairbanks
> Fairbanks, AK 99775-6660
> 301C Chapman and 410D Elvey
> 907 474-7693 and 907 474-7199 (fax 907 474-5394)
> <0001-DMDestroyVI-needs-to-go-after-end-of-for-loop-or-els.patch>
