[petsc-dev] failure of new parallel configure
Matthew Knepley
knepley at gmail.com
Tue Mar 3 14:45:07 CST 2015
On Tue, Mar 3, 2015 at 2:37 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Tue, 3 Mar 2015, Matthew Knepley wrote:
> > Okay, I pushed the fixes for the MPI stuff. Lets see how next does now.
> I see the following issue with 'make all'
Is that a configure problem?
Also note that I removed a cycle in the configure graph. mpi4py depends on
PETSc.Configure, but Configure also depended on it which was crazy.
Matt
> Satish
> CLINKER /home/balay/petsc/arch-linux2-c-debug/lib/libpetsc.so.3.05.3
> gmake[2]: Leaving directory '/home/balay/petsc'
> gmake[1]: *** No rule to make target 'mpi4py-build', needed by
> 'all-gnumake-local'. Stop.
> gmake[1]: Leaving directory '/home/balay/petsc'
> Now to check if the libraries are working do:
> make PETSC_DIR=/home/balay/petsc PETSC_ARCH=arch-linux2-c-debug test
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150303/26f1b23e/attachment.html>
