[petsc-dev] failure of new parallel configure
Tue Mar 3 14:49:37 CST 2015
On Tue, 3 Mar 2015, Matthew Knepley wrote:
> > > Okay, I pushed the fixes for the MPI stuff. Lets see how next does now.
> > I see the following issue with 'make all'
> Is that a configure problem?
> Also note that I removed a cycle in the configure graph. mpi4py depends on
> PETSc.Configure, but Configure also depended on it which was crazy.
Well configure is supporsed to call mpi4py.py - that creates an empty
'mpi4py-build' make target. [similarly for petsc4py]
Somehow this has to happen without a circular dependency?
Satish
