[petsc-dev] failure of new parallel configure
Tue Mar 3 14:37:23 CST 2015
On Tue, 3 Mar 2015, Matthew Knepley wrote:
> Okay, I pushed the fixes for the MPI stuff. Lets see how next does now.
I see the following issue with 'make all'
Satish
     CLINKER /home/balay/petsc/arch-linux2-c-debug/lib/libpetsc.so.3.05.3
gmake[2]: Leaving directory '/home/balay/petsc'
gmake[1]: *** No rule to make target 'mpi4py-build', needed by 'all-gnumake-local'.  Stop.
gmake[1]: Leaving directory '/home/balay/petsc'
Now to check if the libraries are working do:
make PETSC_DIR=/home/balay/petsc PETSC_ARCH=arch-linux2-c-debug test
