[petsc-dev] Seeking OLCF users complaining about poor build times
Thu Feb 26 17:37:21 CST 2015
On Thu, 26 Feb 2015, Barry Smith wrote:
>   Satish,
>     Thanks,  unfortunately since this number is so good this means you need to run another test with master and all packages on mira. (by my reckoning the Metis, hypre and superlu_dist all support parallel builds so should be much faster with master)
will do. Note: Metis, parmetis, hypre will use parallel
build. superlu_dist,fblaslapack will user sequential build - so these
two might still dominate the build times.
Satish
>     Maybe mira is not such a bad compile server after all.
