[petsc-dev] Seeking OLCF users complaining about poor build times
Victor Eijkhout
eijkhout at tacc.utexas.edu
Thu Feb 26 17:20:12 CST 2015
> On Feb 26, 2015, at 3:52 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> time ./configure --download-hypre --download-metis --download-parmetis --download-superlu_dist --download-fblaslapack --with-debugging=0 --with-c2html=0 PETSC_ARCH=arch-test COPTFLAGS="-O3 -fast" FOPTFLAGS="-O3 -fast" CXXOPTFLAGS="-O3 -fast"
[login3:petsc-3.5.3:7] time ./configure --download-hypre --download-metis --download-parmetis --download-superlu_dist --download-fblaslapack --with-debugging=0 --with-c2html=0 PETSC_ARCH=arch-test COPTFLAGS="-O3 -fast" FOPTFLAGS="-O3 -fast" CXXOPTFLAGS="-O3 -fast"
Configuring PETSc to compile on your system
=============================================================================== WARNING! Compiling PETSc with no debugging, this should only be done for timing and production runs. All developme be done when configured using --with-debugging=1 =============================================================================== TESTING: checkCLibraries from config.compilers(config/BuildSystem/config/compile*******************************************************************************
UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
C libraries cannot directly be used from Fortran
Successful compile:
Source:
program main
end
Executing: mpif90 -c -o /tmp/petsc-KqceB4/config.setCompilers/conftest.o -I/tmp/petsc-KqceB4/config.setCompilers -fPIC -O3 -fast /tmp/petsc-KqceB4/config.setCompilers/conftest.F
Successful compile:
Source:
program main
end
Pushing language FC
Popping language FC
Executing: mpif90 -o /tmp/petsc-KqceB4/config.setCompilers/conftest -fPIC -O3 -fast /tmp/petsc-KqceB4/config.setCompilers/conftest.o -Wl,-rpath,/opt/ofed/lib64 -L/opt/ofed/lib64 -Wl,-rpath,/opt/apps/limic2/0.5.5/lib -L/opt/apps/limic2/0.5.5/lib -Wl,-rpath,/opt/ofed/lib64 -L/opt/ofed/lib64 -Wl,-rpath,/opt/apps/limic2/0.5.5/lib -L/opt/apps/limic2/0.5.5/lib -ldl -Wl,-rpath,/opt/apps/intel13/mvapich2/1.9/lib -L/opt/apps/intel13/mvapich2/1.9/lib -lmpich -lopa -lmpl -libmad -lrdmacm -libumad -libverbs -lrt -llimic2 -lpthread -Wl,-rpath,/opt/ofed/lib64 -L/opt/ofed/lib64 -Wl,-rpath,/opt/apps/limic2/0.5.5/lib -L/opt/apps/limic2/0.5.5/lib -Wl,-rpath,/opt/ofed/lib64 -L/opt/ofed/lib64 -Wl,-rpath,/opt/apps/limic2/0.5.5/lib -L/opt/apps/limic2/0.5.5/lib -Wl,-rpath,/opt/apps/intel13/mvapich2/1.9/lib -L/opt/apps/intel13/mvapich2/1.9/lib -Wl,-rpath,/opt/apps/intel/13/composer_xe_2013.2.146/compiler/lib/intel64 -L/opt/apps/intel/13/composer_xe_2013.2.146/compiler/lib/intel64 -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.4.7 -L/usr/lib/gcc/x86_64-redhat-linux/4.4.7 -Wl,-rpath,/opt/apps/intel/13/composer_xe_2013.2.146/compiler/lib/intel64 -Wl,-rpath,/opt/apps/limic2/0.5.5/lib -Wl,-rpath,/opt/ofed/lib64 -Wl,-rpath,/opt/apps/intel13/mvapich2/1.9/lib -limf -lsvml -lirng -lipgo -ldecimal -lgcc_eh -lirc -lirc_s -Wl,-rpath,/opt/ofed/lib64 -L/opt/ofed/lib64 -Wl,-rpath,/opt/apps/limic2/0.5.5/lib -L/opt/apps/limic2/0.5.5/lib -Wl,-rpath,/opt/ofed/lib64 -L/opt/ofed/lib64 -Wl,-rpath,/opt/apps/limic2/0.5.5/lib -L/opt/apps/limic2/0.5.5/lib -Wl,-rpath,/opt/apps/intel13/mvapich2/1.9/lib -L/opt/apps/intel13/mvapich2/1.9/lib -Wl,-rpath,/opt/apps/intel/13/composer_xe_2013.2.146/compiler/lib/intel64 -L/opt/apps/intel/13/composer_xe_2013.2.146/compiler/lib/intel64 -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.4.7 -L/usr/lib/gcc/x86_64-redhat-linux/4.4.7 -ldl
Possible ERROR while running linker: exit code 256
stderr:
ipo: remark #11001: performing single-file optimizations
ipo: remark #11006: generating object file /tmp/ipo_ifortNhWLZj.o
/usr/bin/ld: cannot find -ldl
Popping language FC
compilers: Error message from compiling {Cannot compile/link FC with mpif90.}
**** Configure header /tmp/petsc-KqceB4/confdefs.h ****
Seem the "-fast" confuses the intel compiler. We have bad experiences with it anyway, so we don't advise people to use it.
Victor.
