[petsc-dev] Should the STREAMS benchmark output be added to	.gitignore?
    Jed Brown
    jed at jedbrown.org
    Fri Aug 21 10:09:06 CDT 2015
Patrick Sanan <patrick.sanan at gmail.com> writes:
> Attached.
It would make sense to list the other executables at this time.  Also,
if you use git format-patch or send-email (or a pull request), then your
authorship is recognized when we merge it.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150821/1864b2bf/attachment.sig>
