[petsc-dev] Should the STREAMS benchmark output be added to	.gitignore?
    Patrick Sanan
    patrick.sanan at gmail.com
    Wed Aug 26 11:18:07 CDT 2015
PR #360 (off master but maybe should be off maint) adds the executables in
src/benchmarks to .gitignore and fixes a couple of minor things noticed
while building them . I didn't build everything in streams/ , since I'm not
configured with OpenMP, etc.
On Fri, Aug 21, 2015 at 5:09 PM, Jed Brown <jed at jedbrown.org> wrote:
> Patrick Sanan <patrick.sanan at gmail.com> writes:
> > Attached.
> It would make sense to list the other executables at this time.  Also,
> if you use git format-patch or send-email (or a pull request), then your
> authorship is recognized when we merge it.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150826/5ecf0123/attachment.html>
