[petsc-dev] Should the STREAMS benchmark output be added to	.gitignore?
    Patrick Sanan
    patrick.sanan at gmail.com
    Fri Aug 21 02:02:00 CDT 2015
Attached.
On Fri, Aug 21, 2015 at 4:41 AM, Jed Brown <jed at jedbrown.org> wrote:
> Patrick Sanan <patrick.sanan at gmail.com> writes:
> > I end up with these as untracked files sometimes:
> >     src/benchmarks/streams/MPIVersion
> >     src/benchmarks/streams/scaling.png
> > Is there any reason to not .gitignore them?
> No.  Patch welcome.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150821/462096ff/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150821/462096ff/attachment.obj>
