[petsc-dev] patch for subcomm
    hong at aspiritech.org
    Thu Apr 23 10:40:48 CDT 2015
Stefano:
> It  seems to me that the current code for PetscSubcommSetTypeGeneral
> assumes that all colors will be provided within a range
> [0,max_color_value_provided].
> The current patch (which simply zeroes the subsizes array) extend the code
> when there are holes in the colors' set.
I'll check it, then patch petsc-release. Thanks!
Hong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150423/42dca118/attachment.html>
