[petsc-dev] patch for subcomm
    Stefano Zampini
    stefano.zampini at gmail.com
    Thu Apr 23 03:39:46 CDT 2015
It  seems to me that the current code for PetscSubcommSetTypeGeneral
assumes that all colors will be provided within a range
[0,max_color_value_provided].
The current patch (which simply zeroes the subsizes array) extend the code
when there are holes in the colors' set.
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150423/f937c23a/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150423/f937c23a/attachment.obj>
