[petsc-dev] patch for subcomm
    Hong
    hzhang at mcs.anl.gov
    Fri Apr 24 10:12:42 CDT 2015
Stefano:
Your patch is pushed to maint branch. Thanks!
Hong
On Thu, Apr 23, 2015 at 10:40 AM, hong at aspiritech.org <hong at aspiritech.org>
wrote:
> Stefano:
>> It  seems to me that the current code for PetscSubcommSetTypeGeneral
>> assumes that all colors will be provided within a range
>> [0,max_color_value_provided].
>> The current patch (which simply zeroes the subsizes array) extend the
>> code when there are holes in the colors' set.
> I'll check it, then patch petsc-release. Thanks!
> Hong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150424/9b08329e/attachment.html>
