[petsc-dev] PETSc blame digest (next) 2015-04-15
    Jed Brown
    jed at jedbrown.org
    Thu Apr 16 16:51:43 CDT 2015
Fande Kong <fdkong.jd at gmail.com> writes:
> SO. How to merge
> https://bitbucket.org/petsc/petsc/branch/pr192/Fande-Kong/scalable-matincreaseoverlap/master
> to my own branch. And then I can fix bugs there, send a pull request. It
> should be simple, but I do not know.
git pull --ff-only https://bitbucket.org/petsc/petsc pr192/Fande-Kong/scalable-matincreaseoverlap/master
Typically you'll have a named remote (git remote -v) for the PETSc
repository, in which case you can substitute that name for the https
URL.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150416/b4e699f0/attachment.sig>
