[petsc-dev] PETSc blame digest (next) 2015-04-15
    Fande Kong
    fdkong.jd at gmail.com
    Thu Apr 16 16:40:09 CDT 2015
SO. How to merge
https://bitbucket.org/petsc/petsc/branch/pr192/Fande-Kong/scalable-matincreaseoverlap/master
to my own branch. And then I can fix bugs there, send a pull request. It
should be simple, but I do not know.
On Thu, Apr 16, 2015 at 3:08 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Dmitry (duh), you need to tell him how to access that repo from his
> current location inside his forked clone; it is git mumbo jumbo that you
> need to tell him and document for future people in this situation.
> > On Apr 16, 2015, at 4:01 PM, Dmitry Karpeyev <karpeev at mcs.anl.gov>
> wrote:
> > Fande,
> > The branch Barry is referring to was created in the petsc repo (
> bitbucket.org/petsc/petsc) and contains some clean up fixes that you need
> to merge into your branch before working on it further.
> > Cheers,
> > Dmitry.
> > On Thu, Apr 16, 2015 at 3:50 PM Fande Kong <fdkong.jd at gmail.com> wrote:
> > Hi Barry,
> > how to merge the branch
> pr192/Fande-Kong/scalable-matincreaseoverlap/master to my branch? I did not
> figure out?
> > reshut2-69-67-dhcp:petsc-matincreaseoverlapnew livia$ git fetch && git
> checkout pr192/Fande-Kong/scalable-matincreaseoverlap/master
> > remote: Counting objects: 3997, done.
> > remote: Compressing objects: 100% (2388/2388), done.
> > remote: Total 3997 (delta 2758), reused 2837 (delta 1598)
> > Receiving objects: 100% (3997/3997), 944.99 KiB | 1.55 MiB/s, done.
> > Resolving deltas: 100% (2758/2758), completed with 1147 local objects.
> > From https://bitbucket.org/Fande-Kong/petsc-matincreaseoverlap
> >    56f9468..f1c23e0  master     -> origin/master
> > error: pathspec 'pr192/Fande-Kong/scalable-matincreaseoverlap/master'
> did not match any file(s) known to git.
> > Fande,
> > On Wed, Apr 15, 2015 at 4:36 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >   You never never never want to fix anything in the branch next. You can
> checkout the branch pr192/Fande-Kong/scalable-matincreaseoverlap/master
> which is mentioned in response to your pull request, merge that into your
> branch you made the pull request on, then fix stuff there. Then make a new
> note on the pull request page saying you have made fixes; then I can merge
> them into pr192/Fande-Kong/scalable-matincreaseoverlap/master and then into
> next again for more overnight testing.
> >   Barry
> > next is only a place to put stuff for tests; you should never branch off
> of it or make changes to it directly.
> > > On Apr 15, 2015, at 4:33 PM, Fande Kong <fdkong.jd at gmail.com> wrote:
> > > Hi Developers,
> > > I contributed a scalable matincreaseoverlap. But I received this
> message about some complier errors and warnings on multiple platforms. I
> was wondering if you give an instruction to test all codes on different
> platforms. And how could I get a clone of next branch. My code works well
> with current development version, but have some compiler warnings and
> errors in the next branch.
> > > Thanks,
> > > Fande,
> > > On Wed, Apr 15, 2015 at 8:00 AM, PETSc checkBuilds <
> petsc-checkbuilds at mcs.anl.gov> wrote:
> > > Dear PETSc developer,
> > > This email contains listings of contributions attributed to you by
> > > `git blame` that caused compiler errors or warnings in PETSc automated
> > > testing.  Follow the links to see the full log files. Please attempt
> to fix
> > > the issues promptly or let us know at petsc-dev at mcs.anl.gov if you
> are unable
> > > to resolve the issues.
> > > Thanks,
> > >   The PETSc development team
> > > warnings attributed to commit
> https://bitbucket.org/petsc/petsc/commits/9d01615
> > > Rewrite an implementation of matincreaseoverlap
> > >   src/mat/impls/aij/mpi/mpiov.c:133
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/04/15/build_next_arch-opensolaris-misc_n-gage.log
>  "/export/home/petsc/petsc.clone-2/src/mat/impls/aij/mpi/mpiov.c", line
> 133: warning: argument #7 is incompatible with prototype:
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/04/15/build_next_arch-linux-cxx-cmplx-pkgs-64idx_churn.log
>  /sandbox/petsc/petsc.clone-2/src/mat/impls/aij/mpi/mpiov.c:133:10: error:
> no matching function for call to 'PetscCommBuildTwoSided'
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/04/15/build_next_arch-linux-pkgs-64idx_thrash.log
>  /sandbox/petsc/petsc.clone-3/src/mat/impls/aij/mpi/mpiov.c:133:10:
> warning: passing argument 7 of 'PetscCommBuildTwoSided' from incompatible
> pointer type
> > >   src/mat/impls/aij/mpi/mpiov.c:169
> 169: warning: argument #7 is incompatible with prototype:
>  /sandbox/petsc/petsc.clone-3/src/mat/impls/aij/mpi/mpiov.c:169:10:
> pointer type
>  /sandbox/petsc/petsc.clone-2/src/mat/impls/aij/mpi/mpiov.c:169:10: error:
> > >   src/mat/impls/aij/mpi/mpiov.c:76
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/04/15/build_next_arch-mswin_ps3.log
>  C:\cygwin\home\sbalay\PETSC~1.CLO\src\mat\impls\aij\mpi\mpiov.c(76) :
> warning C4022: 'PetscMemzero' : pointer mismatch for actual parameter 1
> warning C4090: 'function' : different 'const' qualifiers
> > > To opt-out from receiving these messages - send a request to
> petsc-dev at mcs.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150416/66296bf4/attachment.html>
